1. Lawko's Avatar
    Howdy folks.
    Just came from a nexus 6. I use a folder and put speed dials into it for the techs I call frequently.
    When I make the speed dials with the phones built in contacts or with Google contacts. Upon a reboot the names disappear. See pics.
    I've factory reset the phone and it still does it.
    All the contacts are imported from Gmail. No idea why two work fine. Rest don't. Any help appreciated.
    Attached Thumbnails P20 pro speed dials-screenshot_20180820-184128.jpg   P20 pro speed dials-screenshot_20180820-184340.jpg
    08-20-2018 08:11 PM
  2. Lawko's Avatar
    Just wiped the phone again and created the widgets after the phone booted and logged into my gmail account. Same problem.
    08-20-2018 08:42 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! I prefer using the Direct Dial widget, since that's a one-touch call. Does your phone have that widget? If so, does that still lose the name label?
    08-21-2018 05:31 PM
  4. Lawko's Avatar
    Finally got this figured out.... When i create the first widget i drop it on the home screen. The 2nd widget gets dropped ontop of the 1st to create the folder. Those 2 always work. The rest are created and dropped directly into the folder and that was the problem. If i create each widget and drop it onto the home screen and then move it into the folder it works fine. Hate not having stock android.
    09-16-2018 01:28 PM
  5. nlm's Avatar
    It's a launcher issue. I use a different launcher that creates speed dialing differently and no problems. Which launcher are you using?
    09-18-2018 11:21 AM
  1. Help! Samsung Pro J7 - Purple Spots
    By Brenda Nguyen in forum Ask a Question
    Last Post: 08-20-2018, 04:07 PM
  2. Huawei P20 Lite lagging
    Last Post: 08-19-2018, 04:48 PM
  3. Why can't I hear the dial ringing when calling my mom?
    Last Post: 08-19-2018, 04:14 PM
  4. Voice recording on Xiaomi Redmi Note 5 Pro
    By aix123 in forum Ask a Question
    Last Post: 08-19-2018, 04:03 PM
  5. LG G7 vs Huawei mate 10 pro
    Last Post: 08-19-2018, 01:10 PM
