1. albie999's Avatar
    Is there a way to set default mode to charging only? When I plug my phone into usb in the car, it asks for charging, transfer files etc ... I would like it to default to charging only and not keep asking me
    09-20-2018 12:29 PM
  2. Rukbat's Avatar
    It asks, but it should default to charging. If it doesn't, that's Huawei's choice (Google wrote Android to default to charging), and there's nothing you can do to change it without rewriting Android.
    09-20-2018 01:18 PM
  3. albie999's Avatar
    It defaults to charging ... but displays a pop up window ... rather than just defaulting
    09-21-2018 06:37 AM
  4. kupaku's Avatar
    >Settings
    >System
    >Developer options
    >Always prompt when connecting to USB (Disable this one)
    That's it!
    09-21-2018 12:17 PM
  1. Galaxy S7 Edge continuously reboots when using full power mode
    Last Post: 09-20-2018, 02:18 PM
  2. Turn off vibrate in silent mode galaxy note 8
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 09-20-2018, 02:11 PM
  3. Turn off vibrate in silent mode galaxy note 8
    Last Post: 09-20-2018, 12:23 PM
  4. Replies: 1
    Last Post: 09-20-2018, 10:54 AM
