    When I first got my P20 Pro it would last over 2 days just normally and could go for a week on ultra power saving mode.
    Now it will still last a full 24 hours but thats 24+ hours less than it did just over a month ago.
    Is this just because now I have many apps installed or is there something else that may be the problem?
    Cheers,
    Chris
    10-08-2018 07:19 PM
  2. nlm's Avatar
    Look at the app usage under Settings>Battery
    10-10-2018 09:21 AM
  3. andrew_ackley's Avatar
    Cheers,
    Chris
    It's probably an app that you've downloaded that's doing something to your battery in the background.
    10-10-2018 10:30 AM
  4. Rukbat's Avatar
    Have you been running it as far down as you could before recharging it? You can totally kill a lithium battery in a month like that. 40% should be your "charge or turn off" point.
    We don't use lithium batteries because they can handle deep discharging, we use them because they're light (lithium is the lightest metal aside from hydrogen) and because we can make thin phones with them, and that's what people want. In order to get that, you have to live with a 40% minimum. The idea, especially now that replacing a battery isn't just "buy one on Amazon for $10) is to make the battery last as long as possible, not to make the charge last as long as possible.
    10-10-2018 02:23 PM
  5. Visc's Avatar
    Kill a battery in a month sounds a bit much
    10-10-2018 05:05 PM
  6. JZ VR's Avatar
    Uninstall FB and Messenger app, with them installed while idle the battery would go down over 10% in 10 hours or so, with them gone it went down 1% in 10 hours or so, huge difference. Or another app could be eating battery in the background.
    10-18-2018 06:52 AM
  1. Replies: 1
    Last Post: 10-08-2018, 02:20 PM
  2. How can i get rid of the split screen on my tablet
    Last Post: 10-08-2018, 02:06 PM
  3. I need to replace Battery for S7 SM-G930T,
    By Android Central Question in forum Samsung Galaxy S7
    Last Post: 10-08-2018, 01:26 PM
  4. I need to replace Battery for S7 SM-G930T,
    Last Post: 10-08-2018, 10:20 AM
  5. How can I get back on my tablet
    Last Post: 10-08-2018, 09:43 AM
