Huawei p20 pro freezes and i have to restart it to use it again.
  • Thread starter Android Central Question
  • Start date
A
I dont know what happend but by p20 pro Huawei freezes and i cant use it at all... It happens maybe 3-4 times a day, since im using it alot, what can i do to make it stop? Any suggeston?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,590
4,729
113
Welcome to Android Central! It can be hard to pinpoint these kinds of issues, since it's often related to some app you installed. To figure out which app it is, you typically have to uninstall them one by one until the problem goes away, but if it's only happening 3-4 times a day, that can be pretty tedious.
You can try booting into Safe Mode and using the phone for a day to see if the problem still happens. If not, it's likely due to one of the apps you installed. https://androidforums.com/threads/how-to-start-huawei-p20-pro-in-safe-mode-finally-solved.1286670/
guylenn49
