    Hi,
    so i bought a P20 pro week ago, and so far i love it, but i have few issues as a long iOS user and it really bothers me..
    1)Can i view separate notifications from same app on lock screen. Ex. someone texts me and it only show one notification except 4 messages which i received from someone in messenger or whatever chatting app. Can i fix that anyhow?
    2)also gestures like split screen can i turn it off when i randomly swipe left or right, i get this glittering line and it's annoying me.
    Thank you for your responds.
    Marek.
    12-03-2018 10:40 AM
  2. B. Diddy's Avatar
    I moved this to the P20 Pro forum for more specific traffic.
    12-03-2018 10:48 AM
  3. nlm's Avatar
    1. If you have a password on the lockscreen you will be required to unlock the phone when tapping a notification. On the home screen if multiple notifications from the same app are queued in the same banner there is a little arrow you can tap to expand the banner and see the first part each of them, up to I believe 3 or 4, with the rest indicated by a + and a number. But on the lockscreen the notification banner can not be expanded; tapping the arrow to expand is a command to unlock the screen and open the app.
    2. settings>smart assistance>motion control>split screen>off
    12-03-2018 04:25 PM
  4. Marek Bova's Avatar
    Thank you yeah it helped guess i have to get used to it : )
    12-04-2018 01:49 PM
  1. I have a galaxy s8 plus and...
    By laceyjoxo in forum General Help and How To
    Last Post: 12-08-2018, 11:36 PM
  2. Replies: 13
    Last Post: 12-07-2018, 06:04 PM
  3. Does p20 have OIS or not, once and for all?
    By CellyPhoner in forum Huawei P20 & P20 Pro
    Last Post: 12-03-2018, 04:14 PM
  4. Samsing S8+. All app notifications turned on but no notifications come up, all are hidden
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 12-03-2018, 11:20 AM
  5. Replies: 0
    Last Post: 12-03-2018, 01:21 AM
