1. selderij's Avatar
    I'm trying to get notification count badges for all apps, not just the limited list that is offered. I also want them to stay after I've cleared the status bar. This used to work on my Samsung with Nova Launcher, but on my Huawei P20 Pro. It doesn't work and I really miss this.
    Any ideas? Thanks
    01-13-2019 03:49 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Just to clarify, are you using Nova on your P20 Pro as well, or is it EMUI? If it's EMUI 9, my understanding is that it prevents 3rd party launchers now.
    01-14-2019 02:09 PM
  3. selderij's Avatar
    It's Emui 9. Nova works, except for the notifications.
    01-14-2019 04:35 PM
  4. B. Diddy's Avatar
    And you're using the TeslaUnread add-on for Nova?
    01-14-2019 06:53 PM
  5. selderij's Avatar
    Yes!
    01-15-2019 08:58 AM
  6. nlm's Avatar
    I'm using two 3rd party launchers on EMUI 9 (one for the main, the other for the private).
    01-15-2019 09:32 AM
  7. nlm's Avatar
    Did you try changing Settings>Notifications>App Icons Badges>Display Mode?
    01-15-2019 09:34 AM
  8. B. Diddy's Avatar
    Or open your Nova Settings, tap Notification Badges, and double check that the style chosen is something besides "None."
    01-15-2019 10:15 AM
  9. Rukbat's Avatar
    As for the default launcher (on almost all phones and tablets) the badges in Pie are now a count of the notifications still left to read, not the number of calls, texts, emails, etc. Complain to Google if you don't like it. (I haven't heard anyone say they did.)
    01-15-2019 04:49 PM
  10. selderij's Avatar
    Thanks all. It's not solved yet. I'll keep trying. 😉 @Rukbat: you make it sound like I'm complaining to you in person. I'm just looking to restore a functionality that I really liked.
    01-16-2019 10:54 AM
  11. B. Diddy's Avatar
    I thought the unread count badges have always been the unread count, not the total count.
    01-16-2019 11:33 AM
  1. Archive several messages on Android
    Last Post: 01-14-2019, 03:56 PM
  2. IMEI and serial number are not on the back of my Samsung s9
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 01-13-2019, 12:26 PM
  3. Countdown on lockscreen I did not make.
    By jules317 in forum Ask a Question
    Last Post: 01-13-2019, 03:02 AM
  4. Bootloop on Sony Ericsson android smartphone
    By hans henrik buur in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-13-2019, 02:55 AM
  5. Google voicemail not picking up on Galaxy S9
    Last Post: 01-12-2019, 11:10 PM
