Originally Posted by
Simon Beauchamp Mine is on standard already but the way the AI sharpens photos is very aggressive. I've read the AI on the Mate 20 Pro is less so because it runs EMUI 9. I was just wondering if the same is true of the P20 Pro running the same software.
When you take a photo in auto mode and when you see the little tag popping up in the screen, then thats the IA filter.... so when you quickly press the small X then the filter will go off.
The best trick i always use is to shoot in pro mode so that no AI kicks in and when you want the AI then just use auto mode.
