    Hi All,
    Ever since I performed the EMUI update to version 9.0.0.168 the bluetooth performance has significantly reduced. Tidal constantly skips with my Sony headphones and my use has not changed - same areas etc.
    I have repaired the devices, restarted the phone and wiped the cache partition. None of which has helped. I do have high sound quality enabled to optimise for sound quality but this was never an issue before the update.
    Has anyone suffered similar problem or have a suggested fix?
    Thanks
    Ashley
    01-30-2019 05:39 AM
  2. spantch101's Avatar
    Hi All,
    Thanks
    Ashley
    I'm using the WH-CH500 and having no issues on the new update. If anything it fixed the skipping issues i was having with my Uconnect 8.4an in my Ram
    Yesterday 08:18 AM
  1. Charging an S8+ with an older genuine Samsung charger
    By jdocdp in forum Samsung Galaxy S8 & S8+
    Last Post: 01-31-2019, 05:12 PM
  2. Changing the giga Hertz channel on a router box to comply with phone
    Last Post: 01-30-2019, 02:55 PM
  3. Replies: 2
    Last Post: 01-30-2019, 01:10 PM
  4. Bluetooth visibility
    Last Post: 01-30-2019, 10:00 AM
  5. Unable yo connect samsung u flex bluetooth to redmi note please help it out
    Last Post: 01-29-2019, 02:03 PM
