1. damo's Avatar
    Is anyone using them? After 3 weeks, I'm finally getting used to them! Sliding from the edge of the screen to go back requires a certain knack as it sometimes opens the next page, but when you get used to it, it's quite good
    01-30-2019 07:32 AM
  2. crsts's Avatar
    hi,
    i like the gestures based navigation for a while now and i've used nova launcher for that. now with emui 9 nova is not working properly and i was trying to adjust to the emui 9 gestures.
    to say the least, these gestures are very limited and i'm extremely annoyed by the lack of a gesture to open the notifications bar as it's out of reach.
    yes, you have the nav bar with an extra button for the notifications, but this makes no sense when having gestures and one key navigation.
    any smart solution that i somehow missed?
    thanks,
    cristi s
    02-03-2019 02:44 AM
  3. damo's Avatar
    I'm using Nova as well and don't have any problems. I just pull down with 2 fingers to open the navigation screen, bit this only works on the home screen
    02-03-2019 03:27 AM
  4. RiTCHiE007's Avatar
    No, i am so in love with the fingerprint navigation that i find all the others just to much work for the thumb.
    pault8084 and bembol like this.
    02-13-2019 06:12 PM
  5. nlm's Avatar
    Ditto. I find the finger print navigation the easiest and most consistent.
    02-13-2019 07:49 PM
  6. spantch101's Avatar
    Yea, I've been using this single button NAV since i got the phone and find anything else to be unsatisfactory now. i actually don't mind having the chin on the bottom of the screenn. I have difficulties when on screen buttons reach the lower extremes for accidental touches .
    02-15-2019 07:06 AM
  7. bembol's Avatar
    I tried it but went back.
    Besides I hate that the FPS isn't being used and just sitting there.
    02-17-2019 09:16 AM
  1. Deleted my OS on Samsung On5, no backup!
    Last Post: 01-30-2019, 01:17 PM
  2. Hello I have a Samsung galaxy note 5 does anyone know how to root it without pc
    By Android Central Question in forum Samsung Galaxy Note 5
    Last Post: 01-30-2019, 12:12 PM
  3. Has anyone found a fix for the full screen pop up ads on Galaxy S7?
    Last Post: 01-30-2019, 11:53 AM
  4. Can’t delete messages on messenger tried normal routes do not work
    Last Post: 01-30-2019, 10:25 AM
  5. Interner tabs shifted to the right
    Last Post: 01-30-2019, 10:24 AM
