    I've recently had an issue with my Huawei P20 Pro, I've had it for about 4 months but this issue has only recently started. The microphone doesn't seem to be working on any apps, snapchat and video recordings are not picking up any sound and Okay Google doesn't even work when I say it, even when I go on to Google it still won't pick up any sound. I've restarted my phone and that fixed it temporarily, I've turned off and on microphone permissions on the apps affected but that still doesn't seem to work. Has anyone else had this issue and were able to fix it?
    Thanks would appreciate some feedback and help.
    03-08-2019 11:17 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does it work normally in Safe Mode? https://www.getdroidtips.com/huawei-p20-pro-safe-mode/. You'll only be able to test preinstalled apps, but this can tell you if the problem is due to some app you installed, or if it's a system problem.
    03-09-2019 12:43 AM
  1. Issue with Google Play Music syncing
    Last Post: 03-09-2019, 12:55 AM
  2. S10+ Bluetooth Thoughts/Issues
    By lyingfromyou in forum Samsung Galaxy S10 & S10+
    Last Post: 03-08-2019, 11:26 AM
  3. How can I remove camera from lock screen from Huawei Y9 2019?
    Last Post: 03-08-2019, 06:39 AM
  4. Android pie issues on samsung galaxy s9+
    Last Post: 03-07-2019, 07:32 PM
  5. 1 UI or Pie issues
    By Ro Klei in forum Samsung Galaxy Note 8
    Last Post: 03-07-2019, 06:53 PM
