Problem with wifi login..
  • Thread starter Android Central Question
  • Start date
A
I have a P20 pro and I am trying to connect to wifi that requires you to input credentials. When I click to connect it brings up http:// platform. hicloud. com /generate. But the screen goes black and says 404 not found. Can anyone advise. As this only seems to be a problem when trying to connect on my p20 pro and not on other handsets
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,541
4,675
113
Welcome to Android Central! Does it immediately give you the 404 page, or does it try to show something else first, and then go to the 404 page?
Kellymoss1
Opens up chrome window, which I presume is for entering credentials then loads black with 404 not found. Does it with all WiFi that needs credentials.
Samiira Cat
3
I have the same problem with my Huawei P20 smart - I think after an OS update of the phone. I use my home WiFi since years with the same credentials and it used to work with THIS PHONE until something like 2 months. Sometimes (with good luck?) I get a normal connection with internet - is it possible that the repeater in between makes a difference?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,541
4,675
113
Welcome to Android Central! Forget the wi-fi network from your phone, then reboot your router by unplugging its power for about 30 seconds. Reconnect to the wi-fi network -- do you get the same problem?
Samiira Cat
3
B. Diddy you are my HERO!
I never expected the FTTH-router to be the problem! My phone connects without problems, my tablet works in the last edge of the living room - it seems even the connected repeater works better. I'll keep you informed if problems reoccur.
THANK YOU!
planeboy
