Dell Technologies Cyber Savings Event - Up to 45% off
    Hello everyone. I have just bought new Huawei p20 pro hoping it will give better battery time. However,within 2 days of usage I am starting to feel upset with my phone's battery I issue. After 100% charge the battery lasts for about 6-7hr only. And the usage includes only reading news articles, web surfing & may b few videos.
    Plus all my settings are at minimum after watching a YouTube video on the same subject for this same device. My phone is on power mode with smart resolution. Network mode is 3G. Can someone please tell me if this is normal even I am not using it for heavy duty purposes like videos or games.
    Many thanks in advance.
    John
    06-29-2019 07:29 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html. You'll have to register on this forum first. https://forums.androidcentral.com/as...community.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    06-29-2019 01:09 PM
  3. John Romerro's Avatar
    Thank you for your prompt reply. I'll definitely do this and will get back to you.
    06-29-2019 01:55 PM
  4. John Romerro's Avatar
    Hello here are the details. Can you please take a look. Thanks
    Attached Thumbnails New Huawei P20 pro battery drain fast-screenshot_20190703-092927.jpg   New Huawei P20 pro battery drain fast-screenshot_20190703-070645.jpg   New Huawei P20 pro battery drain fast-screenshot_20190703-070636.jpg   New Huawei P20 pro battery drain fast-screenshot_20190703-070624.jpg   New Huawei P20 pro battery drain fast-screenshot_20190703-070614.jpg
    New Huawei P20 pro battery drain fast-screenshot_20190703-070507.jpg   New Huawei P20 pro battery drain fast-screenshot_20190703-070451.jpg   New Huawei P20 pro battery drain fast-screenshot_20190703-070603.jpg   New Huawei P20 pro battery drain fast-screenshot_20190703-070522.jpg
    07-03-2019 01:53 AM
  5. dov1978's Avatar
    8hrs Screen On Time with 34% remaining seems good to me!
    It also says you get an average of almost 12hrs Screen On Time per full charge. That's great battery life
    John Romerro and B. Diddy like this.
    07-03-2019 05:46 AM
  6. John Romerro's Avatar
    Thank you for your reply.
    07-03-2019 06:25 AM
  7. B. Diddy's Avatar
    Yeah, I agree -- 8 hrs of screen-on time on one charge is unusually good. Most phones give about 4-5 hrs at best! If you're saying that the phone lasts only 6-7 hrs on standby, that'd be a problem, but if you're using it a lot, then that's not cause for concern.
    07-03-2019 09:42 AM
  8. 2ISAB's Avatar
    I've also noticed battery drained after The EUI 9 update.
    check some of the apps they allow you to upload your backup during or while you sleep at a certain hour while it's charged or plugged into the charger whatever sorry
    07-09-2019 12:27 PM
  9. 2ISAB's Avatar
    Edit
    My freaking GPS was on and I have no idea how it turned on there's no notification for i or you should see me some battery now just an FYI
    07-09-2019 01:11 PM
  1. Trump reverses Huawei ban!
    By dc52ltr in forum Huawei Mate 20 & Huawei Mate 20 Pro
    Last Post: 09-02-2019, 11:42 AM
  2. How i can root my huawei honor 7 lite?
    By Android Central Question in forum Honor 7
    Last Post: 06-29-2019, 07:22 AM
  3. How i can root my huawei honor 7 lite?
    Last Post: 06-29-2019, 07:03 AM
  4. How do I root Huawei sensa lte
    By iam2019354 in forum More Huawei Phones
    Last Post: 06-29-2019, 06:47 AM
