1. TruckerDrew86's Avatar
    I'm a truck driver from Canada that is in the US and my carrier roams with at&t and T-Mobile mostly where Ive travelled..
    Sadly my phone always wants to go onto the t mobile network where I'm driving for best signal and so on
    But when I'm stopped for the night I want to be on the at&t network cause alot of places I've been the t mobile data is nearly unusable. When I go into network setting and manually choose the at&t network the setting will go back to automatically select network and then after half hr or so even if I've been in the exact same place with good signal and data the phone will automatically switch back over to t mobile
    Is there any way to actually disable that automatic select network setting so I can lock onto a specific network when I'm sitting still?
    07-01-2019 06:44 PM
  1. Smart Lock - trusted places problem
    By tpapictures in forum LG G6
    Last Post: 09-06-2019, 08:34 AM
  2. Lock screen clock won't change
    By wdfrancis58 in forum Samsung Galaxy Note 8
    Last Post: 07-07-2019, 05:12 PM
  3. How can i lock my screen on the movie for my daughter
    Last Post: 06-30-2019, 10:34 PM
  4. Why does my android open windows when the screen lock is on.
    Last Post: 06-30-2019, 02:59 PM
  5. Lock onto network while roaming
    Last Post: 06-28-2019, 08:26 PM
