1. Stewart Townsend's Avatar
    Just recently my p20 pro phone has decided that on WiFi networks that I've connected to previously i.e home and my parents it will connect but showing no network but then next to the network name it says login authentication required but then a android notification appears asking me to sign in I click it and it takes me to a virgin troubleshoot page saying click here to fix which I do, it then goes around as a percentage but then says unable to fix. After a while it connects as normal. Is this a normal thing to happen or should I be worried.
    08-03-2019 08:29 AM
  2. Rukbat's Avatar
    It sounds like something Virgin may have changed. First, "forget" the connection and create it again. If that doesn't fix it, contact Virgin and ask. (I'm assuming that Virgin is your internet provider. If not, turn off mobile data when connecting to WiFi.)
    08-03-2019 12:33 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! What if you forget those networks and then reconnect -- does the same thing happen again later?
    08-03-2019 12:43 PM
  1. Tmobile V40 WiFi Calling turning its self off
    By IAmSixNine in forum LG V40
    Last Post: 08-05-2019, 10:22 AM
  2. Why is my phone not connecting to my computer?
    Last Post: 08-03-2019, 02:56 PM
  3. Enable Android Wifi Hotspot without data ?
    Last Post: 08-03-2019, 02:11 PM
  4. How do I do a software update on a Samsung Galaxy J7 Crown without wifi?
    Last Post: 08-02-2019, 04:10 PM
  5. How can I do a software update on a Samsung Galaxy J7 Crown without wifi?
    Last Post: 08-02-2019, 02:04 PM
