1. Ash Shepherd's Avatar
    Hi All,
    I love my P20Pro, but 1 thing realy gets me.
    On approx 75% of calls if I hold my phne in my left hand at approx 45°(ear to mouth) my caller says 'are you under water?' I change the phone to my right hand at approx 45°(ear to mouth) and my caller says great I can hear you now, no problems.
    There is no lint/dust in the mic hole.
    I have used the voice recorder to test holding the phone in the left and right hand mic operation... the recordings were the same!!!
    Any ideas???
    Thnx
    01-31-2020 01:10 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! See where the primary mic is located: https://usermanual.wiki/Huawei/HUAWE...lpdf.426442166. Is it possible that part of the phone is getting obscured when you hold the phone in your left hand?
    01-31-2020 01:18 PM
  3. mustang7757's Avatar
    I would suggest putting in safe mode also see how the calls are in either hand .
    01-31-2020 01:54 PM
  4. Rukbat's Avatar
    The voice recorder uses the mic at the top, the phone (when not using the speakerphone) uses the mic at the bottom - and you're probably covering it with a finger or your palm when you hold the phone in your left hand. Hold the phone up near the middle, not at the bottom.
    01-31-2020 05:30 PM
  1. Note 9 or Note 10 Lite?
    By Pog1 in forum Buyers Guides
    Last Post: 03-31-2020, 12:07 PM
  2. Replies: 6
    Last Post: 02-01-2020, 11:05 AM
  3. How can i Permanently Disable Samsung Voice Input on Galaxy S9?
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 01-31-2020, 10:14 PM
  4. Why am I not getting notifications from my S10 on my watch?
    By Android Central Question in forum Samsung Galaxy S10 & S10+
    Last Post: 01-31-2020, 12:27 PM
  5. Note 9 or Note 10 Lite?
    By Pog1 in forum General Help and How To
    Last Post: 01-31-2020, 11:05 AM
