Guys iam using mate 20 pro since months now and very happy with the phone... P30 Pro just launched here in India with pre order u getting free GT watch... Just confused
Any owners of P30 Pro can help me here
1) how's are the speakers
2) does it have notifications light
3) how fast is in screen finger print
4) display compared to mate 20 pro
5)battery life
Thank u
Or I should wait for Mate 30 pro
I've got both Mate 20 Pro and P30 Pro and here are thoughts on the above.
1. Loudspeaker is Mono, so worse than Mate 20 Pro, however the Acoustic Display earpiece for calls is great and better than the standard earpiece in Mate 20 Pro.
2. Nope, no Notifications Light, the AOD of the P30 Pro in EMUI9.1 saves it though, as it supports 3rd party apps.
3. In screen Fingerprint Scanner of the P30 Pro is a major leap from the Mate 20 Pro, it's faster and a lot more reliable.
4. P30 Pro display is a stepback from the Mate 20 Pro display in quality, however the Size and Smaller notch are great, I can now see more notifications.
5. Battery life on the P30 Pro is better than Mate 20 Pro which already had legendary battery life. The Mate 20 Pro battery should get better with EMUI9.1.
To end off, I'd say wait for the Mate 30 Pro as it will bring all the P30 Pro benefits, with all the Mate 20 Pro benefits like Higher Resolution display, but with newer SoC.
