1. Robert1985's Avatar
    Are there any good anamorphic lenses available for the Huawei P30 Pro? Some with a dedicated case (not the ones with wobbly clips, no thanks) and which also works while the phone's optical and electronic image stabilizations are active (without showing black bars/shadows left and right in your recordings)?
    I asked Moment if they are going to produce a case for the P30 Pro just a few moments ago. Will update here when I get a reply.
    08-20-2019 03:47 AM
  2. Hermes Hidayat's Avatar
    Other than Moment. Rhinoshield should have it too but they don't.
    08-20-2019 06:37 AM
  3. Robert1985's Avatar
    I don't even see an anamorphic lens on Rhinoshield's official website...
    I found a Wolffilms anamorphic lens with a dedicated case for the P30 Pro on Amazon (Germany), but I don't know if it will produce black bars / shadows on the sides due to the P30 Pro's image stabilization.
    Using a gimbal is not a solution for me though because I am not going to carry it around all day in crowded places.
    08-20-2019 07:58 AM
  4. Mafiatounes's Avatar
    Thanks exactly what i was looking 4, i have a Zhiyun smooth 4 which is going up for sale soon, i will go for a dji 3 which is smaller and more travel friendly.
    08-20-2019 03:43 PM
  5. Robert1985's Avatar
    I got a reply from Moment that they don't have a case for the P30 Pro in their pipeline, but they sent me a link to a survey where I could sign that I would like to see a case for this phone being made.
    Here's the link to their survey:
    https://docs.google.com/forms/d/e/1F..._kJBA/viewform
    If you find the time, you could sign there as well. Select "Other" in the device selection and enter "Huawei P30 Pro".
    I also found another anamorphic lens with a quick fit case on Amazon, called the
    "Apexel 1.33x Anamorphic Lens with Phone Case for Huawei P30 Pro",
    but that doesn't look very trustworthy as they show a generic image for every device their cases are available for, and the price is very low as well.
    08-21-2019 03:45 AM
  6. Hirsti44's Avatar
    Apexel 1.33x anamorphic lens comes with a case for the p30 Pro and uses Filmic Pro.
    10-17-2019 07:18 AM
  7. ptkelly's Avatar
    I bought a Moment telephoto lens and a Moment wide-angle lens. One, I forget which now, had vingeting on my Pixel 2. I wrote Moment and they replied it was because of the Pixel's larger sensor.
    I said they should have warned me and the response was that I could crop the vignetting off.
    I gave the lenses to my nephew when I gave him the Pixel 2.
    11-03-2019 02:27 PM
  1. Usage Scenarios. What will you use the S Pen for?
    By thefoss in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-22-2019, 10:18 AM
  2. Why do I keep getting a download request for something titled "f.txt"?
    Last Post: 08-20-2019, 01:33 AM
  3. What's the latest update for a samsung galaxy note 4 smart phone
    Last Post: 08-19-2019, 07:28 PM
  4. Why can't I find any screen replacements for the Samsung Galaxy A10e?
    Last Post: 08-19-2019, 06:49 PM
