    My P30 Pro seems to be changing notification and other settings when it enters power saving mode.
    I understand while it is in power saving mode that certain things are turned off, etc but after charging these settings don't reset. I will have to go reset my auto brightness, some apps suddenly don't display notifications, etc, etc.
    Any ideas on what is causing this??
    09-07-2019 06:50 PM
  2. belodion's Avatar
    To what percentage do you have to recharge before the phone exits power-saving mode, and does it in fact do so? https://forums.androidcentral.com/sh...d.php?t=409154
    09-07-2019 06:59 PM
  3. garrettmerner's Avatar
    I don't know exactly what percentage it changes back on. It does appear to turn off as when you go into the settings it is marked off.
    09-07-2019 07:32 PM
  4. garrettmerner's Avatar
    Could it be the updating the phone does every night? Somehow resets apps?
    Ive had to reset notifications for Gmail, FB, Instagram. Notification dots dont go away. Auto brightness always turns itself on. Ill open an app which says i have 0 notifications and itll say 6 when i get in there...only for them to be old.
    09-07-2019 07:38 PM
  5. Rukbat's Avatar
    Power saving saves power by not allowing the apps on the list to run unless you run them manually - so of course you won't get notifications. Take the apps you want notifications from off the list (disable power saving for them).
    09-09-2019 05:19 PM
  1. Unexpected life changing feature!
    By Casualballer in forum LG G8 ThinQ
    Last Post: 09-15-2019, 02:08 PM
  2. How do I make a custom message, changing, lock screen wall paper?
    Last Post: 09-09-2019, 05:56 AM
  3. how to change battery percent to numbers
    Last Post: 09-07-2019, 05:56 PM
  4. Can I change the picture of a contact to one that she send to me?
    Last Post: 09-07-2019, 04:30 PM
  5. Lock screen settings not working
    Last Post: 09-06-2019, 01:57 PM
