1. Stwutter's Avatar
    Recently, I've not been getting Google Calendar notifications on my P30 Pro. I have them set to notify me at time of event. It works for a bit, and then they stop. I have all the usual Huawei restrictions turned off. I have uninstalled & reinstalled, and cleared data numerous times. I even deleted the current version and installed and APK of an older version, but the same happens. Seems to be after a few hours or so each time.
    Anybody else have the same issue or a solution?
    10-06-2019 12:31 PM
  2. Galactic Zoo's Avatar
    10-07-2019 06:38 AM
  3. Stwutter's Avatar
    Cheers.
    That's more a syncing thread. My syncs fine.
    My issue is notifications/alerts I have set not coming thru.
    10-07-2019 06:48 AM
  4. Galactic Zoo's Avatar
    Sorry, I really must learn how to read! I found this which I hope helps Seems like the battery saver is the culprit
    10-07-2019 08:25 AM
  1. Calendar event locations
    By eric002 in forum Android Auto
    Last Post: 10-16-2019, 12:45 PM
  2. [SOLVED] Google is requiring a lock screen - I don't need or want it!
    Last Post: 10-07-2019, 12:45 PM
  3. App downloaded from google playstore doesn't show on phone
    Last Post: 10-06-2019, 10:25 PM
  4. A10 notification issue
    By Android Central Question in forum WhatsApp for Android
    Last Post: 10-06-2019, 09:48 AM
  5. A10 notification issue
    Last Post: 10-06-2019, 04:31 AM
