1. thinthatch's Avatar
    As a first time Huawei P30 Pro user and to save me trawling through all the threads, can anybody advise as to how I can do the above?
    10-07-2019 03:48 AM
  2. dov1978's Avatar
    You'll need to Google it I'm afraid. There's no setting on the actual phone to change it as it's carrier specific. You need to find out and enter the long code in the phone app and dial it to change the ringing timeout before it goes to voicemail.
    Just search for 'how to change ringing timeout before going to voicemail on (whatever your carrier is)
    10-07-2019 04:12 AM
  3. Rukbat's Avatar
    Call your voicemail and listen to the menu. If you don't hear it, go to the additional or extended menu.
    If you're in the US, figure 5 seconds per ring (it's by time, not by number of rings) and add 2 seconds, to allow for the fact that what you hear and what the caller hears aren't synchronized. The maximum time is usually 30 seconds.
    If you still can't do it that way, call your carrier's customer service number and ask them to reset it for you.
    10-07-2019 12:18 PM
  1. Today my note 8 was hit by a couple of cars
    By Swishatoosweet in forum New to the Forums? Introduce Yourself Here!
    Last Post: 10-22-2019, 01:13 AM
  2. Has anyone used a screen protector on their fold
    By Ricksanchez32 in forum Samsung Galaxy Fold
    Last Post: 10-21-2019, 02:21 PM
  3. Why cant I answer my Pixel3 now when it rings?
    By Android Central Question in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 10-14-2019, 06:50 AM
  4. hi, i have samsung s4 cell. it is not turning on. how to reset it?
    Last Post: 10-06-2019, 09:18 PM
