    Hi,
    Since a couple of months I've been having issues with my p30pro.
    For some
    reason every now and then, the pictures I've taken get misformed.
    Out of the blue, it can be after a couple of days or after a couple of hours, pictures are suddenly unwatchable and have bars in the picture, or colors become inverted etc.
    It seems to be done randomly to the pictures, and there is no action taken that causes this on my part.
    First I thought it was because of WhatsApp. That a picture that I sent was then unusable afterwards. But I've noticed now it also happens to photos not being sent via WhatsApp.
    Than I thought it was because of the gallery app so I installed another one and used only that one. Didn't change a thing.
    I have a standard p30pro, have not rooted it etc. Installed every update made available trough the system..
    This is becoming very frustrating and annoying that this happens on such a high end smartphone without any reason.
    Photos I have taken are now sometimes unusable which cause me to miss moments captured with my camera.
    The camera btw is the only resao' I've purchased the p30pro.
    Does anyone know this problem? Does anyone knows how this can be solved.
    If needed I can provide some examples of misformed photos.
    Many thanks.
    03-01-2020 01:49 AM
  2. Galactic Zoo's Avatar
    Where are you storing your photos? Internal storage or SD card?
    Any similarities with the results complained of here? https://piunikaweb.com/2019/04/24/hu...rted-by-users/
    03-01-2020 06:33 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Galactic Zoo is on the right track -- if you're saving photos to the SD card, they're more likely to get corrupted, since SD cards are inherently less reliable.
    Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    03-01-2020 12:58 PM
  4. Arnevst's Avatar
    Thanks for the reply.
    I used indeed an SD card to store pictures taken with my p30pro.
    I've just changed the storage option again to internal storage. Hope this will help.
    It shouldn't happen though in my opinion. It make the SD card a bit useless.
    Thanks.
    03-02-2020 01:32 PM
  5. Arnevst's Avatar
    Here are some examples.
    Attached Thumbnails Big in system p30pro?-screenshot_20200301_090719.jpg   Big in system p30pro?-screenshot_20200301_090635.jpg
    03-02-2020 01:33 PM
  6. B. Diddy's Avatar
    It ideally shouldn't happen, but that would be in an ideal world. The unfortunate reality is that SD cards are much less reliable than onboard storage (even if they're from a well-known brand like Sandisk). In addition, counterfeit cards are still a rampant problem, especially if you buy cards from online sellers (as opposed to bricks & mortar retail stores). I always recommend against using an SD card as the sole storage for any important data. It's convenient, yes, but it's a good idea to backup or sync that data somewhere on a regular basis.
    03-03-2020 12:03 AM
  7. doohsun's Avatar
    I've got this happen to Samsung phones as well when I had the Samsung phone I use to have issues with it not being recognized or won't mount and there were times my photos were corrupted that's why I prefer the on storage I don't care about the micros sd slot or nano slot. They're too unreliable. I rather have bigger storage on my phone and not worry about it. Nowadays 128gb is plenty, anything less than that I wouldn't even bother especially with the photos and videos being so big.
    03-03-2020 12:24 PM
  1. My tempered screen protector has a crack in it on Moto G6
    By Android Central Question in forum Moto G
    Last Post: 03-03-2020, 09:56 PM
  2. Why is there a bell with a line through it in my texting ?
    Last Post: 02-29-2020, 10:30 PM
  3. For the A20, why is there a bell with a line through it in my texting?
    Last Post: 02-29-2020, 10:25 PM
  4. Replies: 14
    Last Post: 02-29-2020, 10:12 PM
  5. My tempered screen protector has a crack in it on Moto G6
    Last Post: 02-29-2020, 06:40 PM
