    but when it connected to my PC and i pressed on to the volume up and down button at the same it shows fastboot and rescue mode ...What can i do now?
    05-02-2019 06:42 AM
  2. Rukbat's Avatar
    Since you need the power button to select what you're at either in the bootloader (what you call fastboot - fastboot is a program) or recovery, you'll just have to get the power switch (which is what's not working - the button is just a piece of plastic) replaced.
    05-02-2019 03:03 PM
  1. Why does my tecno uninstall instagram. Tecno camon 10
    Last Post: 05-02-2019, 05:25 PM
  2. My phone died while in odin mode
    Last Post: 05-02-2019, 03:12 PM
  3. why my twitter account "cannot retrieve message at this time"
    Last Post: 05-02-2019, 03:08 PM
  4. Why can 3rd party apps still use background mobile data when it's tunred off?
    Last Post: 05-02-2019, 03:07 PM
  5. How to create a playlist in Gear S3
    By Steve Swift in forum Samsung Gear S3
    Last Post: 05-02-2019, 05:58 AM
