1. gonmigas's Avatar
    The unlocking of the screen P8 does not always work . Sometimes I have to slide my finger more than once to access the phone . Anyone else feel the same difficulty ? Are there any suggestions ? thanks
    07-18-2015 02:07 AM
  2. jerrywall's Avatar
    I had this problem too before I noticed that there is a rather stiff plastic protection sheet over the display that makes response a lot worse. Look at the speaker, if there is an oval cutout around the sensor, the speaker and the camera you have to remove the sheet.
    Skickat från min HUAWEI GRA-L09 via Tapatalk
    gonmigas likes this.
    07-18-2015 02:14 AM
  3. jerrywall's Avatar
    In the setting you can disable the lockscreen and only use the security screen if the unlocking feels troublesome.
    07-18-2015 02:37 AM
  4. gonmigas's Avatar
    Thanks for you reply. I change the lock screen style to "before the dawn". It's not perfect but it works better.
    07-18-2015 06:29 AM
  5. gonmigas's Avatar
    No plastic...
    07-18-2015 06:32 AM
  6. jerrywall's Avatar
    You can also go to Themes and scroll to the far right and select Customize at rhe bottom and then select Lock screen and as effect select "none". That made it better for me.
    07-18-2015 08:53 AM
  7. gonmigas's Avatar
    Now it's perfect. :=)
    I havent seen that option. Thanks
    07-19-2015 07:29 AM
  1. Why can't I get Google voice commands to work in apps?
    Last Post: 07-18-2015, 02:01 AM
  2. Why can i not download apps on to my Samsung Galaxy S3 Mini??
    Last Post: 07-18-2015, 01:50 AM
  3. Replies: 0
    Last Post: 07-18-2015, 01:47 AM
  4. Verizon home screen
    Last Post: 07-18-2015, 01:16 AM
  5. Why doesn't my Samsung Galaxy Y boot even after a hard reset?
    Last Post: 07-18-2015, 01:03 AM
