1. Hauwei p9's Avatar
    I have a hauwei p9, I may have got the wet, left in rice for 6 hours,the phone reboots ok as normal. But when try to unlock it doesn't open,the lockscreen has shrunk to about 45% to the right side of the screen. I have rebooted a number of times, wipe cleaned the cache, rebooted, all ok. It's not opening from lockscreen, fingerprint identification not working lockscreen not opening, so no chance of inputting pin no. Then finally left it back in the rice for a further 48 hours. Again rebooted , still lockscreen is about 45% and not opening,so finally factory reset and nothing, still the same, I thought it would be a software issue, please help, phone is really good don't really want to go buy another, especially now there is no Google play
    10-01-2020 10:33 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Unfortunately, it sounds like hardware damage from the water. The rice trick is not a guaranteed solution -- next time this happens, refer to this guide: [GUIDE] Oh, no! My Phone got Wet! - Android Forums at AndroidCentral.com. Sorry!
    10-01-2020 10:59 AM
  1. Any suggestions for a screen protector that will work with the fingerprint scanner?
    By bobmurray1212 in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 10-08-2020, 03:51 AM
  2. Screen Over Sensitive
    By Jerry Schuller in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 10-02-2020, 01:58 PM
  3. Not able to choose different notification sounds after Samsung update?
    Last Post: 10-01-2020, 10:48 AM
  4. I have an A20 Android what is the bell upper left side of screen
    Last Post: 09-30-2020, 07:21 PM
  5. Replies: 1
    Last Post: 02-14-2015, 07:39 PM
