    Problem with fingerprint scanner
    Lately the fingerprint scanner won't unlock the phone. There's no vibration indicating wrong fingerprint, it just does nothing. When I unlock the phone using PIN it works fine opening top notification panel or scrolling through photos. When I go to settings and fingerprints manager it recognizes my fingerprints without a problem. Even when I lock the phone it works well for couple of times but after a while it stops working again.
    I already switched the phone off and on again but it changed nothong.
    Any advice besides resetting to factory settings?
    Thanks for any help
    02-15-2018 07:12 AM
  2. Maki2707's Avatar
    I have the same problem, have you found a solution?
    03-05-2018 07:09 AM
  3. B. Diddy's Avatar
    See response in your other thread: How to turn on safe mode on Huawei P9
    03-06-2018 01:58 AM
  1. How do I prevent notifications interfering with game play.
    Last Post: 02-12-2018, 10:19 AM
  2. recovering data from an Huawei P10
    By Preston Thomas in forum Huawei P10 & P10 Plus
    Last Post: 02-09-2018, 12:35 PM
  3. Galaxy note 4 problem possibly solved by last update
    Last Post: 02-08-2018, 03:36 PM
  4. my huawei honor 6x wont turn on?
    Last Post: 02-08-2018, 01:05 PM
  5. Replies: 1
    Last Post: 02-08-2018, 12:52 PM
