Hi I have a P9 Lite which I used to connect and back up to my PC. This worked easily. Having had a black screen problem on Windows 10 I did a clean install and reinstalled all my software. However now when I try to connect to the PC with Hisuite I get constantly a box stating allow Hisuite with HDB and it just will not go away. Everything is set as it says it should be but still no go.
If I try to connect with my wifes desktop also running Windows 10 everything goes smoothly. Any advice would be gratefully received. Thanks
