1. Downey91's Avatar
    First of all.. Sorry for bringing up this subject again, but I cant seem to get any decent results with the watch.
    Battery is draining 10% an hour with the following settings:
    Brightness - 3
    WiFi - off
    Gestures - off
    Always on - on
    Cloud sync - off
    Send diagnostics info - off
    I've attached the battery stats.. Not sure if this helps.
    Appreciate always on isn't going to help, but people are getting great results even with this setting on.
    Any help would be much appreciated, only had the watch a few days, so still learning!
    Attached Thumbnails Battery drain 10% an hour-screenshot_20170317-233544.jpg
    03-17-2017 06:54 PM
  2. Premium1's Avatar
    Did you try a factory reset? Seems you may have a rogue app
    03-17-2017 06:58 PM
  3. Downey91's Avatar
    Thanks for the quick reply.. If I factory reset, is there anything I should be doing differently when setting up? Obviously don't want to do the same process in case the same rogue app pulls through (if that's the issue) again appreciate the reply!
    03-17-2017 07:01 PM
  4. jchapman01's Avatar
    Definitely should factory reset. Don't know what else you might do differently tho. I find I rarely need my brightness above 1.
    What watch face do you use? Some watch faces will waste more battery than others. I ended up just sticking with one of the preloaded watch faces, for what that's worth.
    04-24-2017 04:50 PM
  1. Battery suddenly drops 30% during night
    By abovetherim22 in forum LG K7
    Last Post: 03-23-2017, 02:56 PM
  2. Has anyone gotten an update to 7.1.2?
    By bjrosen in forum Nexus 6P
    Last Post: 03-18-2017, 03:19 PM
  3. Zenfone 2 laser will not charge (and its not the battery)
    By SarianaZ in forum ASUS ZenFone 2
    Last Post: 03-17-2017, 01:59 PM
  4. Why is battery draining due to 10249 on android
    Last Post: 03-17-2017, 12:47 PM
  5. Why does my clock keep bouncing back an hour on my s4 mini?
    Last Post: 03-17-2017, 12:36 PM
