Originally Posted by
B. Diddy Hmm. Which apps have been installed from the Play Store on the watch? Do you find that you're getting tons of notifications from any app?
I have installed pandora, Google maps, Google music, Google fit, a messenger app, and keep. I haven't used any yet. The most I've done with the watch was check to text messages.
dadathepanda I'm at 78% off the charger since 7 AM and with screen always on. Definitely something is using up more battery than it should.
Do a factory reset.
Also, are you keeping your phone close by all day? I'm thinking that the watch keeps trying to connect with your phone....
I did a reset last night but it doesn't seem like it did anything. My phone is in my pocket all day so hopefully it's not trying to connect haha.
