nrblank
Hey, I'm trying this method to unroot my inc 2. I flashed froyo which appears to have worked fine. But when I try to reset the HBOOT using the extracted unroot.zip file the first command says
*daemon not running. starting it now on port 5037*
*daemon started successfully*
error: device not found
then every command after that just says
Any suggestions?
Any suggestions?
