1. AllGood's Avatar
    I've noticed a lot better battery life after installing Jager and using SetCPU to setup profiles.
    Anyone else having success with this as well?
    06-30-2010 02:28 PM
  2. sklemp's Avatar
    I've noticed a dramatic increase in battery life just using Jager. I'm not even adjusting the CPU.
    And I even think that I might be using my phone more now than ever since installing the Roms.
    06-30-2010 03:41 PM
  3. Ellerbestyle's Avatar
    What are some of the profiles you have set up?
    07-01-2010 09:01 AM
  4. Bobby9's Avatar
    Doesn't Jager use the undervolt kernal?
    07-01-2010 09:18 AM
  5. AllGood's Avatar
    I have mine set for when it gets to X battery percentage drop CPU down, when the battery gets to Y drop it lower and when it gets to Z drop it lower. Also set it to when the screen is off drop it down to like 386mhz
    07-01-2010 10:22 AM
  6. AllGood's Avatar
    Yes it does
    07-01-2010 10:25 AM
  7. Ellerbestyle's Avatar
    Not sure if it is working for me. I set the cpu to like 800 mhz and it still goes all the way to 998
    07-01-2010 05:48 PM
  8. Bobby9's Avatar
    I think I read that setcpu doesn't work with the undervolt kernal or something like that.
    07-01-2010 07:38 PM
  9. AllGood's Avatar
    i've had no issues with it. the widget doesn't update right nut i've had that issue with the droid as well
    07-01-2010 10:11 PM
