For myself and a few others who have installed a Froyo ROM and the newest Swype beta you may have an issue. When trying to Swype in a word the keyboard just "dings" at you and nothing is entered leaving you having to enter in each letter like a normal keyboard. Well I found a fix and it's pretty simple.
Before doing these steps you will need to snag 'Android Mate' from the market. It's free and extremely easy to use if you are used to using Astro.
You should now have a working Swype installation. Seems sometime during the registration / installation of the keyboard something gets mucked up so this solves that issue. Happy Swyping!
1. If you've attempted any Swype installation, uninstall Swype and Swype Installed using Manage Applications. Also delete any downloaded files related to Swype from downloads folder (using Android Mate).
2. Reboot into recover and wipe cache.
3. Reboot and let phone settle. Reopen Swype email with Installer link. Click link and download.
4. Using Android Mate, open swype_installer.apk in downloads.
5. Run install, but don't open when finished. Just click Done.
6. In Android Mate, navigate to /data/app and confirm that com.swype.apk is in there, and not in /mnt/sdcard/data/app. You may have to hit the backup button once to get to the right spot to find your /data/app folder.
7. Run Swype Installer from Apps Manager in Android Mate. Follow instructions.
8. Should be working now!
