1. volblood's Avatar
    I rooted my htc incredible last night with "unrevoked 3." then i used "titanium backup" root app and uninstalled some apps like skype, vzw navigator, city id... Now my phone goes to "hboot" screen and will not go past it. How can i reinstall the android os and get my phone up and working??? Please help
    10-20-2010 05:35 PM
  2. FD2's Avatar
    Removing those 3 would not cause that. What else did you remove?
    10-20-2010 05:39 PM
  3. FD2's Avatar
    10-20-2010 05:43 PM
  4. Kyle Gibb's Avatar
    Having the stock RUU on hand when rooting is always a good idea for future reference
    volblood likes this.
    10-20-2010 06:17 PM
  5. volblood's Avatar
    not sure... i guess something important.
    10-20-2010 08:21 PM
  6. volblood's Avatar
    Do I need to name the file any specific name?
    10-20-2010 08:22 PM
  7. volblood's Avatar
    I downloaded this file and put it on the sd card but how do I access it on the phone and load it? It's not showing as a .zip file.
    10-20-2010 09:15 PM
  8. FD2's Avatar
    You need to run the exe on a computer and plug your phone in via USB. It will do all the work. Just follow the on screen prompts.
    10-21-2010 10:50 AM
