ssethv
ANDROID OBSESSED
I had the same issue when I came from stock to the nightliesI went from a Virtous ROM to the nightly. Did full wipe so and have nothing to revert back to. I've full wiped 5 times in past 24 hours because I didn't realize restoring system data from Titanium would mess things up until I got help on here. This is first time that everything is running perfectly with no issues so I really don't want to go back through the whole process again. I've been without my phone way too much and it's time consuming.
I'm using Nightly #6. I thought I read somewhere about getting your apps to appear in the market but can't find it now.
If everything is running smooth then I wouldn't mess with perfection either... If the only thing is that your missing a few of your apps then I would just try to remember them and get them from the market (if they are third party apps, then you need to allow to see them). after you find and get your apps back, you need to use ROM manager or whatever you want to save your current ROM.
