1. clintrojan's Avatar
    Hello,
    This is a review of the Rearth Softshell Case.
    Sorry for quality, recorded it with a webcam.
    I recommend this if you are looking for a soft case. It is made with high quality silicone and is very aesthetic. It actually keeps the look of the Inspire while providing protection. There are multiple colors to choose from.
    $16.99
    Rearth USA | Go ahead, judge us by the cover!
    *UPDATE*
    After using this case during a phone call. It seems since the microphone beside the LED Flash is blocked, this case makes the speaker phone unusable. I was getting complaints of "noise in the background" while in a completely silent room. So if you want to use speaker phone and don't want to modify this case on your own, then this will not be for you.
    04-25-2011 07:43 PM
