1. Sarah Horne's Avatar
    Rebooting gives me everything but the actual menu bar, that one pulls down. Also, no battery use bar. My apps are all present, and the ones I downloaded are fine, but connecting to the web, or using anything else just nets a black screen. I can't even set to factory specs. Any advice would be fantastic
    Thanks
    10-30-2014 11:09 AM
  2. Sarah Horne's Avatar
    117 people view this particular thread, and no one has anything to offer...thanks?
    10-30-2014 01:07 PM
  3. LazarX's Avatar
    Have you modified or rooted the unit? You may need to do a hard reset. Also try cleaning out your cache on all apps with something like Lancaster.
    10-31-2014 10:26 AM
  1. Replies: 5
    Last Post: 11-28-2015, 08:12 AM
  2. Replies: 2
    Last Post: 10-30-2014, 12:44 PM
  3. Galaxy S5 or Galaxy S5 Active?
    By Tara Rayburn in forum Samsung Galaxy S5
    Last Post: 10-30-2014, 11:11 AM
  4. Using an old device when not changing your IMEI to your new device
    By DSF767 in forum General Carrier Discussion
    Last Post: 10-30-2014, 10:54 AM
  5. Replies: 1
    Last Post: 10-30-2014, 10:49 AM
