1. David Scherrep's Avatar
    Could I place two Shazam icons on my home screen or would it not allow that because that would create a duplicate? Just curious.
    12-19-2012 08:58 PM
  2. carracerz14's Avatar
    What do you need two of the same icon for?
    Just tried it on my maxx running 4.0 and it allows me to put as many of the same thing as apace allows. Not sure if it's cause I'm on a rom or not, but I'm not going back to stock just to find out
    Sent from my RAZR MAXXIMUS
    12-19-2012 09:01 PM
  3. zkSharks's Avatar
    You should be able to place as many copies of any shortcut or widget that you want. I know it's possible on Jelly Bean, and I'm pretty sure it was just as feasible on previous versions of Android. So the answer is yes.
    As far as why, carracerz14, my guess is to have quick access to Shazam on each homescreen.
    12-19-2012 09:02 PM
  1. A pdf viewer that allows me to rotate the view?
    By Vance14 in forum Android Apps
    Last Post: 11-01-2012, 05:23 PM
  2. Replies: 1
    Last Post: 10-26-2012, 10:32 AM
  3. How to put a file shortcut on my home screen
    By 44pillowspa in forum Sprint Galaxy S III
    Last Post: 07-06-2012, 12:37 PM
  4. is there a battery monitor app that allows me to reset the
    By adaorange in forum Verizon HTC Thunderbolt
    Last Post: 07-10-2011, 03:52 PM
  5. Will a factory reset on a rooted DX allow me to receive the Froyo 2.2 update?
    By sundown220 in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 08-16-2010, 10:49 PM
