1. Deanig_12's Avatar
    Hi all i cant go 6-7 hours without charging my phone i have got an s2 running 4.1.2 my brighness is turned right down andni cant seem to find the problem :|
    07-04-2013 04:43 PM
  2. nickgalaxys4's Avatar
    I have my screen all the way up. I get about a day an a half with my battery. (GS4)
    07-04-2013 04:46 PM
  3. Deanig_12's Avatar
    Maybe i need a new battery if so how long do i charge the new 1 for??
    07-04-2013 04:49 PM
  4. gollum18's Avatar
    You only need to charge it to 100. Contrary to popular belief, there is no need to calibrate your battery. Trust me I'm a software developer.
    Sprint GS3 Running TN's Msg and Chubbs
    07-04-2013 06:28 PM
  5. Deanig_12's Avatar
    Ok i dont get you what do you mean callabrate :s and i dunno if its the battery or not but whenni click on battery in settings its says screen 65% and i dunno what is cause this issue
    07-04-2013 07:12 PM
  6. markray's Avatar
    Reduce the brightness and do not use Automatic, just set it in the lowest option.
    07-06-2013 04:09 PM
  7. catborg's Avatar
    Hey, I had an S2 myself, and it also has really bad battery life. I think the problem is that the battery is getting old. After a certain number of discharge cycles, the amount of charge the phone will hold changes drastically. I bought a new battery, and now the battery life is a lot better.
    07-08-2013 01:08 AM
  1. Does anyone ever feel that this phone is too big?
    By elvisgp in forum Samsung Galaxy Note 2
    Last Post: 08-02-2013, 03:50 PM
  2. SD card is formating automatically
    By JBizz86 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 07-05-2013, 01:48 AM
  3. Replies: 5
    Last Post: 07-04-2013, 06:41 PM
  4. Is light bleed normal on nexus 4?
    By loldroid23 in forum Google Nexus 4
    Last Post: 07-04-2013, 05:50 PM
  5. Blue lines developing on battery screen?
    By magicalwishes in forum Samsung Galaxy S4
    Last Post: 07-04-2013, 03:10 PM
