1. mrsmumbles's Avatar
    Hi all,
    For some reason I'm getting that error message, "problem loading widget", when I try to add one.
    What could be wrong?
    I'm using Apex Launcher and a wallpaper from one of the play store wallpaper apps. Thanks in advance.
    Sent from my LG870 via Tapatalk 2
    10-12-2013 09:08 PM
  2. killthedope's Avatar
    Hi all,
    I am also facing the same issue
    10-12-2013 09:15 PM
  3. mrsmumbles's Avatar
    Another weird thing was I temporarily lost my settings bar on my "Quick Launch" thing. It pulls down from the notifications bar.
    It came back, but I'm not sure what caused that.
    I did put a WiFi toggle widget on my home screen, but I can't seem to get weather on there. I'm wondering if the problem is that I don't actually have one downloaded. But that doesnt make much sense either.
    10-12-2013 10:12 PM
  4. mrsmumbles's Avatar
    I found that there are problems using Apex Launcher unrooted with adding widgets.
    I temporarily switched back to the stock launcher and widgets seem to be loading, though I haven't tried a bunch.
    I was getting used to Apex but I guess I'll have to try Nova and see if the widget problem returns or persists.
    10-13-2013 09:45 AM
  5. mrsmumbles's Avatar
    If I use a downloaded launcher the stock widgets won't load.
    But third party (downloaded) widgets work fine.
    10-13-2013 03:09 PM
  6. mrcblake's Avatar
    I found this on another site and tried it and it worked I no longer have the problem. So here is the fix:
    Open Root Explorer
    Browse to /system
    Click Mount R/W button
    download launcher apk to your sdcard
    browse to launcher apk in root explorer and
    Long Press launcher APK file
    Choose copy
    Navigate to /system/app
    Press Paste button
    Choose Permissions
    Check all the top 9 checkboxes
    Press OK
    Navigate to /system
    Press Mount R/O button
    Restart
    Done
    01-21-2014 07:21 PM
  1. Samsung Galaxy S4 Problem - TomTom
    By S7even_UK in forum General Help and How To
    Last Post: 03-01-2014, 05:38 PM
  2. Galaxy Note 3 Battery problem... I think!
    By FailedState in forum Samsung Galaxy Note 3
    Last Post: 12-19-2013, 04:48 AM
  3. Lockscreen and widgets - your input needed
    By Joker8891 in forum Samsung Galaxy Note 3
    Last Post: 10-12-2013, 10:36 PM
  4. Replies: 2
    Last Post: 10-12-2013, 12:39 PM
  5. Smart Phone Flash Tool Root problem
    By Adnan Shole in forum Legacy Android & Other OS's
    Last Post: 10-12-2013, 09:05 AM
