1. Serge Storms's Avatar
    Hoping someone out there can help. I jut picked up a Samsung Galaxy S3, and I am trying to change my notification sound for text messages. I put an MP3 file in the appropriate folder, and selected it in the settings menu on messaging. It keeps reverting back to the old default message notification sound.
    Has anyone else had this issue- and do you have any idea of how to get it to believe I want to use a different sound?
    Thanks very much for any help you can offer!
    12-19-2013 11:43 AM
  2. Golfdriver97's Avatar
    Thanks cry much for any help you can offer!
    Try clearing cache in recovery then resetting your sounds. http://forums.androidcentral.com/sam...2-s3-tab2.html
    12-19-2013 02:17 PM
  3. Serge Storms's Avatar
    Wiped the cache partition (closest option) in boot menu, no effect.
    When I first set it, things are fine. Then a few hours later when I get a text , the annoying old default sound is back. I tried searching through the directories to see if I could delete it to force the issue, but no luck finding it. I've now placed the new sound in a different directory (where it still shows as an option), and we'll see how that goes.
    12-20-2013 11:28 PM
  1. Galaxy S3 wifi keeps connecting after I turn it off!! Help!
    By usmdesigner in forum Samsung Galaxy S3
    Last Post: 07-19-2016, 12:46 AM
  2. Any news on connecting to WPA2 Enterprise on the S3 with 4.1.2?
    By Dawn Mooney1 in forum Verizon Galaxy S III
    Last Post: 07-09-2014, 09:41 PM
  3. Replies: 1
    Last Post: 12-19-2013, 11:36 AM
  4. google voice won't save to keep - Verizon galaxy s3
    By sk_ghost in forum General Help and How To
    Last Post: 12-19-2013, 10:42 AM
  5. Trouble with Email Notification Settings
    By mbranco978 in forum Sprint Galaxy S III
    Last Post: 12-19-2013, 10:01 AM
