1. alanbk1's Avatar
    Hello all and hopefully someone can help me with this most annoying problem. I have a new Prestigio dual phone PAP5300 running android 4.1.2 (Nice Phone BTW). I moved from IOS on iphone. One of the apps I loved on IOS was the reminder apps that I could set a reminder and the phone would sound an alert. No bother at all in Android I hear you say !! Problem is, any reminder app I have installed does not alert me. They are there, but they do not pop up and appear as overdue when I go into the app . I've installed Life Reminders, Any.do, Wunderlist and none of them Alert me at the appointed time. It's as though Android is somehow overriding the set task if that makes sense. Even Goole Now won't work !! It has to be something simple but for the life of me, I can't solve it.The phone is rooted but I've not put anything on as yet. Any ideas ? Thanks all
    02-17-2014 02:55 PM
  2. wizzrah's Avatar
    Did the phone come with an Alarm? You could set some alarms at different times to remind you of things if other apps do not work for you.
    Maybe you can try these apps as well:
    https://play.google.com/store/apps/d...id=com.bzzzapp: Bzzz reminders
    https://play.google.com/store/apps/d...DoReminder.gen: To do reminder
    https://play.google.com/store/apps/d...bitspin.timely: Timely Alarm Clock
    02-17-2014 03:37 PM
  3. alanbk1's Avatar
    Thanks for the reply. None of those you suggested will work either. Very strange.
    02-17-2014 03:56 PM
  4. wizzrah's Avatar
    Did they not ring either?
    02-17-2014 03:57 PM
  5. alanbk1's Avatar
    No. Really annoying. Has to be something I'm missing
    02-17-2014 04:03 PM
  6. wizzrah's Avatar
    Just for clarification, is it that they don't ring at all? Or is it that they ring at the wrong times?
    02-17-2014 04:09 PM
  7. alanbk1's Avatar
    They don't ring at all
    02-17-2014 04:49 PM
  8. wizzrah's Avatar
    Is your speaker working? Hmm, have you tried to see if some sort of vibration notification works?
    02-17-2014 04:53 PM
  9. alanbk1's Avatar
    I know it's weird. The speaker works, vibrate works etc. When I go into the settings for an app I can select an alert tune etc. But, when I save them, no joy. I'm using google calender as a stop gap measure. Thanks for the reply's
    02-17-2014 04:58 PM
  10. patruns's Avatar
    Try the Google Keep app. You can add quick notes and set reminder times with it.
    02-18-2014 09:41 AM
  11. Devilsbane's Avatar
    I use google calendar for reminders like that. They pop up on my phone, allow me to snooze or dismiss. They'll also pop up if I'm logged into my calendar on my computer.
    I don't remember how, but several years ago I set it up on my computer to sync my outlook calendar with google, so they would pop up there too. I use my computer much less, and never use outlook for reading emails anymore so it isn't really needed for me anymore. But for someone who has outlook up all day, that is another option.
    02-18-2014 12:17 PM
  1. Stuck at boot logo after failed ROM install, please help.
    By Jo K1 in forum Legacy Android & Other OS's
    Last Post: 12-05-2015, 04:35 AM
  2. Replies: 33
    Last Post: 07-07-2015, 02:21 PM
  3. SMS notification sound
    By GoBigRed4 in forum Motorola Droid MAXX
    Last Post: 04-10-2014, 12:36 PM
  4. ROOT error - need help - Sprint LG G2
    By ash0074 in forum LG G2
    Last Post: 02-18-2014, 02:48 PM
  5. Choppy notification audio with NAE
    By mmark27 in forum Sprint Samsung Galaxy S4
    Last Post: 02-17-2014, 12:34 PM
