1. aeronium's Avatar
    Hi all,
    I have a rooted Note 3 andr realize that my battery has been draining like crazy even when I'm not using it. Something like 7-10% per hour.
    The issue seems to improve if I turn mobile data off. And doesn't happen at home when connected to Wi-Fi.
    I've checked with BetterBatteryStats, and found nothing that would actually cause such a huge drain in battery.
    My battery could drain over 50% with only 5 minutes of screen time
    My workplace also has a relatively weak cell signal. Could this be the cause?
    When I try to place the SIM card in my iPhone 4S, the battery only drains 1% per hour. So this issue seems specific to my Note 3.
    Any help would be appreciated!
    Sent from my SM-N9005 using AC Forums mobile app
    03-12-2014 06:22 AM
  2. Golfdriver97's Avatar
    Have you tried a reboot?
    03-12-2014 09:17 AM
  3. aeronium's Avatar
    Like a restart? Yes
    03-12-2014 09:53 AM
  4. Golfdriver97's Avatar
    There might be a problem with the sim reader
    From a Sprint Moto X using AC Forums app
    03-12-2014 10:22 AM
  5. aeronium's Avatar
    Nope, SIM reader works fine
    03-12-2014 04:31 PM
  1. Battery issues, possibly since update?
    By ao7415 in forum Legacy Android & Other OS's
    Last Post: 11-04-2014, 02:20 AM
  2. Note 3: hand wave for quick notifications while in sleep
    By mayconvert in forum AT&T Samsung Galaxy Note 3
    Last Post: 03-13-2014, 09:14 PM
  3. Can an app widget be installed on the lock screen?
    By newbie40 in forum Verizon Samsung Galaxy S4
    Last Post: 03-12-2014, 07:31 PM
  4. Google Android Device Manager
    By jaipreetrana in forum Legacy Android & Other OS's
    Last Post: 03-12-2014, 02:38 PM
  5. Replies: 0
    Last Post: 03-12-2014, 01:11 AM
