1. bfuels1993's Avatar
    AT&T LG G2 Kit-Kat update done, and now my Quite Mode does not come on as it should. No problems before the update, anyone else having this issue?
    03-13-2014 12:26 PM
  2. LGElectronics's Avatar
    During the time that Quiet Mode is supposed to be activated, when you go into the Quiet Mode settings are you seeing both Turn Quiet mode on now and Set quiet time switch set to ON? What indication, if any, are you seeing in the Status bar and notification panel during that time as well? ^SM
    Golfdriver97 and thaig2 like this.
    03-13-2014 06:57 PM
  3. bbj71370's Avatar
    During the time that quite mode is supposed to be activated,turn quite mode on now is not on but the set time and days are set. So it's on from 10:00 pm to 6:00 am. If it's 10:05 pm and I pick up the phone it's not on quite like it's supposed to be. The status bar notification is there because I left it on a couple of days and I cleared it on a couple,no change in activation. That's why I figured I would make a post to see if anyone else had any insight. Any help would be great. Thanks.
    03-13-2014 08:57 PM
  4. Legend124's Avatar
    I am having the exact same issue This only happened after kit kat 4.4 update was installed. Scheduled activation of quiet mode fails to launch.
    03-21-2014 08:58 PM
  5. canadidan's Avatar
    (Already posted in other AC thread, but...) I can confirm the same issue. Quiet mode does not enable at scheduled time. Toggling or modifying the schedule will cause it to activate as expected.
    D803 model with Bell Canada, started after KitKat OTA. Did a factory reset, but that changed nothing.
    03-30-2014 08:56 PM
  6. thaig2's Avatar
    Please. Can I have the contact for someone at LG Support? This is a real issue. Quiet Time has been broken by the update.
    My G2 is an international version just like it came from Korea. Same issue.
    You see last night how I set it but it ignores it and Quiet Mode doesn't turn on.
    Don't try to test it out because it will work. You can't schedule it for 2 minutes from now and stare at it because it will work. You have to leave it set and wait for the next day and the next. Live with it and you'll see it won't work.
    It comes OUT of Quiet Mode when scheduled, but it can't turn it on.
    04-04-2014 07:10 PM
  7. jayochs's Avatar
    same problem here. won't come on. LG, cmon.
    04-16-2014 05:35 AM
  8. JRDroid's Avatar
    One solution is to use a 3rd party app. Agent is a great one. It is a much better quiet mode (as well as other very useful modes) app then any phone has built in.
    04-16-2014 08:24 AM
  1. Big problem: cant mount SD&cant connect to PC
    By DieterW91 in forum HTC One S
    Last Post: 03-19-2014, 12:46 AM
  2. Problem when adding additional Gmail address on Nexus 7
    By Nick Piffle in forum General Help and How To
    Last Post: 03-18-2014, 10:39 AM
  3. 4.4 Problems S4 UK
    By jonnymayne1 in forum Legacy Android & Other OS's
    Last Post: 03-13-2014, 10:14 AM
  4. HTC recovery mode
    By scottsan in forum General Help and How To
    Last Post: 03-13-2014, 09:25 AM
  5. Problems in my Samsung Galaxy S4's Smart Screen Feature
    By Alextodd1 in forum Samsung Galaxy S4 Active
    Last Post: 03-13-2014, 07:35 AM
