1. Karim Yousry's Avatar
    My battery started to drain fast and i dont know why .. i thought because my ram is always used highly .. my ram is 1gb and the average using of it while i'm not opening any apps is about 68% to 73% .. is that even normal !! .. and can this cause my battery to drain !!?
    03-20-2014 03:11 AM
  2. Sharishth's Avatar
    using anything in an smartphone too much can drain the battery specially when it come to hardware. yeah it could be one of the reasons but there are other reasons too. you can always use great apps like clean master (available at play store). Or your phone is old now.another possibilities are that your screen brightness is too high or your wireless connections like Bluetooth or Wi-fi is kept on for a long time or you don't have good battery backup.Sometimes features of phone also takes up much of a battery like nexus 5.
    also try searching for battery saving tips.
    03-20-2014 05:19 AM
  3. Game Zone's Avatar
    There are background apps who are running , drain baterry and RAM freeze them with Titanium Backup or try a task killer
    03-26-2014 09:43 AM
  4. neonworm's Avatar
    Don't use a task killer. It is normal and actually good for the phone if the RAM is full. That is how Android works. Task killers can actually make the phone slower and/or use more battery.
    B. Diddy likes this.
    03-27-2014 12:04 PM
  5. B. Diddy's Avatar
    These two articles might be helpful:
    http://m.androidcentral.com/ram-what...-shouldnt-care
    http://forums.androidcentral.com/amb...ving-tips.html
    neonworm likes this.
    03-27-2014 12:17 PM
  1. Replies: 1
    Last Post: 07-03-2014, 11:49 PM
  2. Wow T-mobile service is bad....
    By Closingracer in forum General Carrier Discussion
    Last Post: 04-03-2014, 09:21 AM
  3. Can I transfer a Note 3 from Verizon to T-Mobile.
    By rndm21 in forum Samsung Galaxy Note 3
    Last Post: 03-24-2014, 12:41 PM
  4. battery doctor app
    By Paskell in forum Google Nexus 5
    Last Post: 03-20-2014, 10:12 PM
  5. How long does the oleophobic coating on the screen last?
    By legaldeejay in forum Verizon HTC One
    Last Post: 03-20-2014, 04:18 PM
