play store home connection timed out
Troy Martin
Problem is simple.
SET YOUR WIRELESS ROUTER TO HOST TCP & UPD PORT FORWARDING TO 5228!
AGAIN PORT FORWARDING TCP & UPD TO 5228 both directions.
Netgear 7550 SETUP - GOTO FIREWALL SETTINGS, SELECT PORT FORWARDING, SELECT ADD, CREATE SERVICE/RULE, ENTER NAME"ANDROID", SELECT PORT FORWARDING, SELECT BOTH UNDER TCP/UPD, ENTER 5228 IN ALL FIELDS, APPLY.
BACK TO PORT FORWARDING MENU, SELECT NEW RULE YOU MADE"ANDROID", SELECT HOST, SELECT YOUR ANDROID DEVICE IN PULL DOWN MENU, APPLY.
DONE.
PROBLEM SOLVED.
kerokekerol
