1. Dhruv Shetty's Avatar
    I have gone searching everywhere for a battery for my xolo q700 phone and it is not available anywhere in bangalore. The service center too doesn't have it. This is very bad as my battery has bulged and even under warranty they cannot replace it.
    04-11-2014 12:35 PM
  2. Sudarshan Sathe's Avatar
    Please use EB615268VU 2500MAH of samsung note 1
    05-12-2014 04:04 AM
  3. Ankur Gambhir1's Avatar
    I had bought a battery from ebay.in battery is working fine here is the link to buy
    Lava Xolo Q700 Q 700 2400 MAH Battery High Quality Free Screen Guard | eBay
    06-05-2014 11:06 AM
  4. Biswajit Nandy's Avatar
    XOLO Q700 battery is not available for more than a month. No solution with service centre or customer care.
    Is Battery of Samsung Note 1( EB615268VU) is really compatible to it? Its price?
    06-09-2014 11:22 AM
  5. Biswajit Nandy's Avatar
    I have been excited getting your option of samsung branded battery. whether Samsung Note 1 means Samsung Galaxy Note-7000?
    If you bother to answer me I will be really grateful. After seeing your advice when I search net I found battery EB615268VUCINU( in Flipkart) and EB615268VU for Glaxy Note N7000. Both are same? <email removed per site rules> Please answer at the earliest.
    06-09-2014 12:56 PM
  6. Sachin Benni's Avatar
    hey fri....
    can we go for consumer court??
    06-14-2014 08:39 AM
  7. singharmeet's Avatar
    Pls dont go for duplicate battery, you'll regrett, as it doenst even works for 10 hours.
    Nokia BL5C works better than duplicates, its available just for 300, and works for over 20 hours. You just need to fill empty space in battery compartment with some thick cardboards.
    drjexpress likes this.
    06-28-2014 01:17 PM
  8. roshinit's Avatar
    can i use xolo q700 battery for xolo q700i..?? coz q700i battery s nt available nywhere...
    08-06-2014 11:36 AM
  9. sarahragan2014's Avatar
    My Battery of xolo q700 it is bulged it is not available anywhere
    08-14-2014 01:24 AM
  10. drjexpress's Avatar
    Bro after full charge how long battery backup...pls pls reply
    09-28-2014 12:48 PM
  11. Satyajit Mukherjee's Avatar
    I have XOLO Q700s. I bought it in January, 2014. So, within 10 months its battery swelled up. Can I use XOLO Q700 battery for my XOLO Q700s.
    XOLO Q700s battery is 1800 maH. But, XOLO Q700 battery is 2400 maH.
    Can I use XOLO Q700 battery for my XOLO Q700s?
    10-28-2014 12:24 PM
  12. singharmeet's Avatar
    Nokia BL5C original one runs for around 20 hours. I tried to buy so called original battery from service center, it also runs for around 24 hours with low usage and I was charged 700/-. Service centers are also selling duplicate batteries at high prices against company price of 499/-. I complained to Xolo Care, they dont say anything.
    02-18-2015 06:14 AM
  13. sabyasachighosh's Avatar
    Hi, you said to use thte SG Note 1 battery ... I have a note 1 battery since so many days..almost a year but I could not insert the battery in any way into the mobile..i have even been to Samsung as well as Xolo showrooms to get help inserting the batteries, no where they could help!! Please tell me how to insert the Note 1 battery into q700 battery slot... the battery is way larger than the slot.
    04-06-2015 06:35 AM
  1. Samsung Galaxy S3 Major Battery Issue
    By Lee Kirby in forum AT&T Galaxy S III
    Last Post: 04-21-2014, 12:23 PM
  2. Phone will not turn on? Please Help.
    By J Bayliss in forum HTC One M8
    Last Post: 04-11-2014, 10:03 PM
  3. Nexus 10 battery?
    By DrGonzo_101 in forum Legacy Android & Other OS's
    Last Post: 04-11-2014, 12:16 PM
  4. Android Not Compatible with USB 3.0??
    By PF82 in forum Legacy Android & Other OS's
    Last Post: 04-11-2014, 11:44 AM
