1. Deanig_12's Avatar
    hi guys i got a new phone yesterday and i set it up and kies found a update all was well working nicely but when i went to go into recovery and tried to clean the cache partition so i clicked that and it said erasing then error :/ dose anyone know what this means or what i can do to fix it? :/
    Thanks all
    05-21-2014 05:00 AM
  2. B. Diddy's Avatar
    Did you buy the phone brand new from a retailer, or used? Or from eBay? Maybe someone rooted it before and did something that interferes with the normal cache wipe process.
    05-21-2014 10:17 PM
  3. Deanig_12's Avatar
    could i not just install the software via kies? see if that fixes it if so ill update tonight
    05-22-2014 05:53 AM
  1. straighttalk att samsung galaxy s4 and apn settings
    By Laci Marie in forum Samsung Galaxy S4
    Last Post: 10-31-2014, 11:36 PM
  2. galaxy ace 3 display problem
    By Mohammed Hasan2 in forum Legacy Android & Other OS's
    Last Post: 05-28-2014, 09:16 PM
  3. Need To Transfer Info From Samsung to Samsung
    By WoodGlue in forum Samsung Galaxy S5
    Last Post: 05-21-2014, 05:56 AM
  4. Help!
    By Millzey13 in forum Legacy Android & Other OS's
    Last Post: 05-21-2014, 05:32 AM
  5. samsung s4 email restriction fix???
    By Ben Vuleta in forum Samsung Galaxy S4
    Last Post: 05-21-2014, 03:20 AM
