Re: why does my tablet's sound get stuck while shutting down
So you're saying that you'll be using your tablet, then suddenly you'll hear one of the system sounds for a prolonged period of time, then the device shuts off on its own. Right?
You might need to do a full factory reset. Go to Settings>Backup & Reset>Factory Data Reset. It will wipe your tablet clean, so backup your data first.
