1. Shahzaib Alam's Avatar
    i have a problem with huawei honor 3c android phone. the problem is that it said that a new update is available, i download it and installed it and it was complete. but phone does not start up and vibrates on pressing the power button and does not show anything and just keeps vibrating after few seconds. what is its problem. please help.
    09-29-2014 12:39 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try booting into Recovery Mode and wiping the cache partition, which won't erase any personal data. Follow the steps in this video, but instead of selecting Wipe Data/Factory Reset, make sure you select Wipe Cache Partition. When complete, then select Reboot System Now.
    I realize that this is a video for the Honor 3X, but I couldn't find one for the 3C. I'm assuming the process is the same.
    Shahzaib Alam likes this.
    09-29-2014 08:00 PM
  3. Khai_Rul's Avatar
    does it work, can solve the problem?
    09-30-2014 07:32 PM
  4. Khai_Rul's Avatar
    can use it that solution?
    10-03-2014 06:00 AM
  5. B. Diddy's Avatar
    Welcome to Android Central! Are you having similar problems with the same phone? You could try the same process yourself--it won't erase any personal data.
    10-03-2014 10:39 AM
  6. nimal_mm's Avatar
    My phone is also having the same issues. My phone is not turning on and the display is unresponsive. I also tried booting in the recovery mode. Please help...
    01-29-2015 08:43 AM
  7. MMohsinlive's Avatar
    Solution is easy:
    Just take the usb cable, plug it in PC and phone, turn it on.. It will run smoothly and soundly
    Goodluck
    07-05-2015 04:15 PM
  8. waqasakmal's Avatar
    yar i m also facing same problem what should i do my phone is not connecting with pc and not go in recovery or any mode it is still vibrating and blank
    jastenesantero likes this.
    12-10-2015 08:06 AM
  9. waqasakmal's Avatar
    12-10-2015 08:13 AM
  10. john emmanuel pinote's Avatar
    we have the same problem with regards to honor 3c and i really dont know how to fix also my problem of my phone. Its kinda sucks !
    01-31-2016 01:51 AM
  11. ali81999's Avatar
    everyone try this method its 100% working
    1. Download Set Up SP Flash Tool version v3.1324.0.177 (Secboot)
    2. Download MTK vcom usb drivers
    3. Download stock recovery signed (renamed stock recovery signed to recovery.img)
    4.Flash through SP Flash Tool version v3.1324.0.177 (Secboot)
    but if this method don't work then,
    5. Put in Stock ROM dload folder into SDCard
    6. Boot into recovery ( Power + Vol Up & Down )
    7. It will auto update.
    Recovery link : Download unbrick h30-u10.zip
    04-27-2016 02:39 AM
  12. Harish kumar bk's Avatar
    10-06-2016 09:09 PM
  13. jastenesantero's Avatar
    oh my god we have the same problem in the same phone! How fix this? huhu T-T
    11-02-2016 02:18 AM
  14. jastenesantero's Avatar
    it doesn't work <l3
    11-02-2016 02:19 AM
  15. Ahsan2003's Avatar
    I have a problem with my 3c. I got it new but did not charge for 3 months and now it is not turning on. When i put it on charging it vibrates and does not show anything. Pls help
    01-04-2017 12:18 AM
  1. New phone or refurbished as warranty exchange
    By dadathepanda in forum General Carrier Discussion
    Last Post: 10-22-2015, 04:28 PM
  2. Skype notifications via Android Wear
    By coreymcl in forum Moto 360
    Last Post: 04-26-2015, 04:35 AM
  3. Why is my screen black but I can hear my phone booting up?
    By anthea wesley in forum Samsung Galaxy S3
    Last Post: 09-30-2014, 06:46 AM
  4. Which phone to get, Droid Maxx or, Galaxy S4? Thank you
    Last Post: 09-29-2014, 05:01 PM
  5. my phone appear to work
    Last Post: 09-29-2014, 02:38 PM
