battery problems on a generic tablet
i recently bought a chinese gaming tablet and it works great but the battery only lasts for 2 hours
my device has these specs
RK3028 chipset (cpu: 1GHz dual core + mali mp2 400 GPU)
512 RAM DDR3
2500 mAh lithium battery
5 inches led screen
frontal and back cameras
android 4.2.2 JB
the battery tab at the setting says that the battery is used 100% by the screen, the gsam battery monitor's appsucker only lists the apps that i use google services are there but it doesnt uses any battery, when i check the running apps it only shows the system UI and the keyboard, yet its using 400 MB RAM
looking on the installed apps i found 3 suspicious ones there are "armfreqtest" "stresstest" and a chinese named app
these 3 have permissons for everything, even the phone and GPS functions that it doesnt has since its a tablet, could these have something to do? is it safe to remove them with titanium backup?
512 RAM DDR3
5 inches led screen
android 4.2.2 JB
