1. flocsy's Avatar
    After I upgraded my nexus 5 to android 5.0 I have the very nice material design notification icons, but unfortunatelly they "lost" some important (well at least interesting) information about the data connections's speed. Up to android 4.4.4 there was a small letter on the icon indicating the connection technology (that pretty much correlates with the speed)
    Is there a way to turn that letter indicator back on? Or is there an app for it?
    11-18-2014 09:05 AM
  2. N4Newbie's Avatar
    There is no cellular data connection when there is an active Wi-Fi connection. So, disable Wi-Fi (or move out of range) and you should see those letters reappear.
    You might also find this app helpful if you are curious about your connections: https://play.google.com/store/apps/d...android.telnet
    11-18-2014 09:09 AM
  1. Cant decide between the Note 4, Moto X, or LG G3
    By SupersoNick_95 in forum Samsung Galaxy Note 4
    Last Post: 02-17-2015, 07:24 PM
  2. Nexus4 updated Lollipop mobile networks enABLE
    By jacpra21 in forum Google Nexus 4
    Last Post: 11-19-2014, 09:02 AM
  3. Replies: 4
    Last Post: 11-18-2014, 09:33 PM
  4. Do I have to change to lollipop?
    By pirateghostabc in forum Legacy Android & Other OS's
    Last Post: 11-18-2014, 01:44 PM
  5. Why can't I get pasted the 4.4.4?
    By pacmanbegins in forum Legacy Android & Other OS's
    Last Post: 11-18-2014, 09:01 AM
